Re: 3pt hitch h
Posted by dej(jed) on May 07, 2007 at 04:39:55 from (67.140.55.147):
In Reply to: 3pt hitch h posted by bbaro on May 07, 2007 at 03:47:54:
Just run a line from one of the pump outlets to the up side of the cylinder. If you have 2 cylinders use a tee and run one line to both of the lift siides of the cylinders.
