Re: 4 terminal voltage regulator
Posted by Bob M on May 07, 2007 at 05:50:13 from (151.190.254.108):
In Reply to: 4 terminal voltage regulator posted by redforever on May 07, 2007 at 01:09:12:
The "correct" wiring is to feed the fuse post from the regulator L terminal. However it will also work wired the other way as you suggest - only difference is the lights may burn a bit dimmer.
