Re: Farmall H starting problems
Posted by Janicholson on May 07, 2007 at 07:48:43 from (199.17.6.122):
In Reply to: Farmall H starting problems posted by sweet48 on May 07, 2007 at 06:53:28:
A weak ignition system will do that every time. Here is a simple test. This method supplies voltage to the ignition with no connection to the regular battery. Jumper a different battery (observe the polarity of the system by grounding the same terminal on this jumping battery as on the regular battery) to the terminal on the supply side of the coil (from the switch, not the terminal with wire going to the distributor) Leave the switch off. Hit the starter and spin the engine. Ill bet it starts up instantly. The coil, condenser, or points may be bad. Start by replacing the points/condenser. Adjust them to .020" when fully open. If the issue still persists, try a different coil. Starter motor drag can also cause this symptom by reducing voltage till it can't find enough spark ti light off, but you indicated it spins freely. Good luck, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
