Re: Farmall H starting problems
Posted by El Toro on May 07, 2007 at 09:20:43 from (64.12.117.8):
In Reply to: Re: Farmall H starting problems posted by sweet48 on May 07, 2007 at 08:11:06:
Pull the coil wire from the mag's cap and hold it within 1/8-1/4" of good ground while someone makes an attempt to start the tractor. Make sure the grounding switch is in the run position. You should have a hot blue fire from that coil wire. Check those points to make sure they're set at .020" on the high point of the cam. Clean them with some 320 wet or dry and then take a cotton swab dipped in alcohol and clean them again. If they're pitted replace them. If the fire from that coil wire is weak you probably need a new coil. One more thing is to make sure the impulse coupling is snapping ok. This gives a hotter spark during the initial startup. Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
