CUB IS CHARGING!!!!!!!!!!
Posted by DAN WV on May 07, 2007 at 16:40:26 from (207.255.218.215):
Well after I completely rebuilt the wiring harness and cleaned everything that I could remove and clean the cub started charging.
It charges at about 9 amps above 1/2 throttle. It seems to maintiain this rate of charge all the time. When I turn on the light switch to the "D" position it discharges by about 5 amps. When I turn it to the "B" position the ammeter runs about at the 0 position.
Is this correct for the tractor?
Thanks.
