Re: Questions on splitting my H (aka basket case)
Posted by JayWalt on May 07, 2007 at 20:30:54 from (70.226.7.112):
In Reply to: Questions on splitting my H (aka basket case) posted by neblinc on May 07, 2007 at 10:23:16:
neblinc,
Be very careful if this is your first split. I have yet to split one, but have had the rear tires off and it was rather nervewrecking. Redunancy is a good idea. When I pulled my right rear tire, I used a big cherry picker (4 ton capacty), and a log chain around the axle. Also had a stand made from 4X4 (4X4's stand directly in top of each other), and a homemade (more then adequate by itself I'm sure) steel jackstand.
Be sure to keep your escape route in the event of failure in mind. Yes I'm paranoid, but one wrong move could mean death. Make sure you have adequate room to run if something goes wrong. Also, I would try to have someone else there for the splitting, just in case something does happen. I dont mean to sound crazy, but I dont want this post to be your last!!
Let us know how it goes!! Get some pics if you can. I'd like to see the stands.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
