806 TA Noise
Posted by 806 TA Noise on May 08, 2007 at 04:02:44 from (71.7.25.252):
I have a noise in the clutch housing of my 806. It only occurs at idle and with the clutch out. (If I depress the clutch or rev up the engine, the noise goes away.) It is a slow grind with the TA lever ahead and a faster one with it back. This leads me to think that maybe it is TA bearings that are not getting oil at slower speeds. I have been using it all spring but am careful not to let it idle with the clutch out. Has anyone had a similar experience? Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
