Super H pto leak
Posted by vally farm on May 08, 2007 at 20:25:57 from (207.69.138.143):
I picked up a new seal...a thin little grean thing, but when I went to replace it, the old seal is a heavy steel piece that seems to suport the output shaft. Where does this little seal go? Do I press the steel foward? seems like that would hit the pto gears. Do I push the steel back? Then the pto would ride on a dry sleeve. I know this can't be this hard. Any ideas? Mike
