Re: Farm All Cub cuts out when hot / fuel line vac
Posted by Mike Finger on May 09, 2007 at 08:36:00 from (24.143.86.63):
In Reply to: Farm All Cub cuts out when hot / fuel line vacuum? posted by Mike Finger on May 06, 2007 at 07:25:21:
Thanks to all of you Cub sages for your replies. The tank was
flaking a fair bit of rust, so I had it acid cleaned and lined last
season, and also installed an in line filter that was purchased at the
local IH dealer. No one commented on the possible complications
of the fuel line heating up a bit - I"ll look into replacing the rubber
tubing with metal just in case. I"ll probably pull the filter, though
many have warned me that gas tank (re) linings don"t always hold
up. I"ll call the dealer too and make sure the filter they sold me was
for a Cub.
