Re: PTO Shields
Posted by Nat 2 on May 09, 2007 at 08:50:12 from (64.80.108.52):
In Reply to: PTO Shields posted by GordoSd on May 09, 2007 at 07:23:38:
The H and SH will use the longest, 13", shield.
That 10" shield fits a regular M or Super M. It's shorter because the distance from the axle to the drawbar hole is the same between an H and M, and the M's rear housing is larger. There's less PTO protruding from an M than an H.
The SMTA will use the shortest, 6" shield. Rather than bolt over the entire PTO, it bolts to the rear of the IPTO unit.
Since you've only got 1 13" shield, you'll have to use the 10" on one of the Hs. Better than nothing, at least.
