FAST HITCH problems...help
Posted by Clefus on May 09, 2007 at 19:09:46 from (75.88.177.58):
I was using a 3 btm -- 14 " fasthitch plow i recently got and I have 2 ???
1 : Someone replaced a share with one that protruded past the shin/landslide about an inch and also doesnt match up with the moldboard edge....it is a 4 bolt pattern 14 inch piece....the other two match up fine on both ends...I got a new Osmundson one at TSC and it also fits the same goofy way...
Where do I get a right one??
2: Same plow...plowing I caught something and tripped a plow back....what is the best way to re-set it.....i had a hair of a time jackin,beatin,pryin, sprayin......
Thanks
