Re: Milky goo from pto on model M? Help!
Posted by Nat 2 on May 10, 2007 at 12:33:25 from (64.80.108.52):
In Reply to: Re: Milky goo from pto on model M? Help! posted by M.Rad. on May 10, 2007 at 10:48:33:
There is only one cavity for gear lube on these tractors. Just drain it out from the bottom, and refill.
Two possibilities for shearing bolts:
1. You're hitting things.
2. The drawbar is flopping around and messing up the alignment, putting undue stress on the driveline.
