Re: 40 h doesn't want to run
Posted by old on May 10, 2007 at 21:31:07 from (4.244.219.129):
In Reply to: 40 h doesn't want to run posted by minn.meyer on May 10, 2007 at 17:53:21:
Check and double check your spark. Sounds more like you have a bad condenrser then a carb problem. If you pull the drian plug from the bottom of the carb if you have a good flow of gas for say 5 minutes check your spark I'll almost bet your not getting a good brite blue spark
