Re: Mag check for beginners
Posted by Steven@AZ on May 11, 2007 at 06:58:50 from (216.67.213.217):
In Reply to: Re: Mag check for beginners posted by Boyero on May 11, 2007 at 00:40:07:
Actually, the magneto will probably generate a better spark during starting because for the distributor type the starter is drawing so much power from the battery there isn't much left to make a spark...
In my experience, my magneto equipped tractors start quickly and run great - the distributor equipped will do the same IF the battery is fairly new and fully charged. The slightest discharge on the battery makes them start hard - when the battery is low on those, I start with the hand crank so more power gets to the distributor.
Also, when I can't afford a new battery my magneto equipped tractors keep on going.
