Re: Pros and Cons to using oil as coolant
Posted by JohnG(TX) on May 11, 2007 at 11:31:09 from (216.136.20.34):
In Reply to: Re: Pros and Cons to using oil as coolant posted by Janicholson on May 11, 2007 at 10:46:58:
Makes good sense, since oil is less dense than water, it would absorb heat faster and hold less energy. I guess the speed at which the oil flows through the system would have to be greater then the speed for the water.
