Re: 230 Fast Hitch problem
Posted by karl f on May 11, 2007 at 16:06:02 from (64.83.221.111):
In Reply to: 230 Fast Hitch problem posted by Tom in SA on May 11, 2007 at 13:13:34:
to research your problem, you could use a softer bolt in place of the pin, when the bolt breaks, that"s a situation that causes your problems. not too soft of a bolt though, as it will stretch and cause other wear you do not want.
hope this helps.
karl f
