Farmall Tractors Discussion Board
Re: Re: Re: Re: 400 engine/starting
Posted by RickB. on May 06, 1999 at 17:47:23:
In Reply to: Re: Re: Re: 400 engine/starting posted by RKS on May 06, 1999 at 02:32:37:
A 400 with enhanced compression will NOT start with a 6 volt system unless EVERYTHING is in perfect shape, ignition, timing, battery, cables, & solenoid.
Post a Followup
: Re: Re: Re: Re: Re: 400 engine/starting
