Re: 400 Throttle Lever
Posted by janicholson on May 12, 2007 at 05:42:19 from (66.216.226.55):
In Reply to: 400 Throttle Lever posted by super991/2 on May 11, 2007 at 19:43:13:
There is a spring on the shaft that applies pressure to the handle toward the toothed strip of metal. that spring has fatigued and can be replaced with a hardware store spring of the same diameter and twice the wire diameter. in the meantime make a #9 wire hook to fasten under the bottom bolt of the toothed strip, and over the handle shank. JimN
