Re: SuperC carburetor
Posted by georgeky on May 12, 2007 at 17:24:05 from (205.188.116.138):
In Reply to: SuperC carburetor posted by Mark Johnson on May 12, 2007 at 16:38:31:
It will say on the carb what kind it is. You can adjust the float and install the new kit yourself. It is a simple chore for a simple carb. The model of carb should be on the top on a disc or a tag mounted on one of the little screws that hold it together.You will need that to get the right kit. The carb should be a Carter, Zenith or Marvel Shebler
