1941 Farmall A cracked block between cylinders
Posted by Bryan Appel on May 13, 2007 at 18:59:08 from (64.12.117.8):
I have a 1941 Farmall A with a cracked block (C113) between two of the cylinders (two cracks total, one crack between cylinders 1 and 2 and the other crack between cylinders 2 and 3). The sleeves appear perfect. When I drained the antifreeze and oil, there were no signs of trouble. However, I have no idea how long either fluid was in the engine (they could have been changed right before I purchased the tractor). Do I need to worry about these cracks? If they are a problem, any suggestions on repair techniques? Thanks! Bryan
