Re: 1941 Farmall A cracked block between cylinders
Posted by Tallperson on May 13, 2007 at 19:42:10 from (165.170.128.66):
In Reply to: 1941 Farmall A cracked block between cylinders posted by Bryan Appel on May 13, 2007 at 18:59:08:
I would probably have the block magnafluxed to discover if the cracks are just external or if there are also internal cracks. If they are just external any compitent welding shop will be able to repair the cracks with cast iron rod. If done correctly the repair should be nearly invisible.
Good luck Tallperson
