Farmall Tractors Discussion Board
Re: H 12 volt conversion, or, duh what kind of car is that?
Posted by Mike McKay on May 06, 1999 at 20:32:56:
In Reply to: H 12 volt conversion, or, duh what kind of car is that? posted by weekend farmer on May 06, 1999 at 10:43:59:
You should be able to ask for a universal 12 volt coil without an internal resistor with screw terminals. the Standard ignition number is a UC12 as best as I remember.or a coil from a 1957 Chevrolet 283 cu in should be the same. Good luck, Mike
Post a Followup
: Re: Re: H 12 volt conversion, or, duh what kind of car is that?
