Re: F-30 Engine Part Numbers
Posted by Nebraska Cowman on May 14, 2007 at 04:14:16 from (65.165.16.220):
In Reply to: F-30 Engine Part Numbers posted by BT in NE on May 13, 2007 at 19:55:24:
Yes, those sound like high compression pistons. 435D is the correct sleeve number. Your parts book might show the number with an "X" which is Assy with probably the packing rings.
