Farmall Tractors Discussion Board
Re: H 12 volt conversion, or, duh what kind of car is that?
Posted by RKS on May 07, 1999 at 02:35:18:
In Reply to: H 12 volt conversion, or, duh what kind of car is that? posted by weekend farmer on May 06, 1999 at 10:43:59:
I think all you need is a ballast resistor to put between the (+) on the old coil and the "dead side of the switch terminal." This is if you have the alternator and voltage regulator, if needed, and know how to install it. The ballast resistor is made of ceramic, about 2-3 inches long, and has a "fuse-like" coiled contact inside it. It shouldn't be much, and you probably don't need a new coil if the old one is ok. RKS
Post a Followup
: Re: Re: H 12 volt conversion, or, duh what kind of car is that?
