Re: Farmall 756 with German 310 ( few Questions)
Posted by nw_bearcat on May 15, 2007 at 05:29:39 from (164.144.240.25):
In Reply to: Farmall 756 with German 310 ( few Questions) posted by migraine on May 14, 2007 at 22:12:37:
third party image
Maybe I just work mine a little too hard, i have trouble keeping it cool. we clip pastures and CRP w/ a 15' batwing, and you get about 4 hours of running in the morning until 10, then you get to go back after 4 in the afternoon, anything more and it just seems to get too hot. we've flushed the rad, running good coolant,and we keep the nose clean. I've been measuring to figure out if i can put a deeper rad. core in there from something like a 1066 to see if that might help
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
