Re: Farmall 756 with German 310 ( few Questions)
Posted by wayne from wi on May 15, 2007 at 05:55:52 from (209.240.206.198):
In Reply to: Re: Farmall 756 with German 310 ( few Questions) posted by Allan In NE on May 15, 2007 at 03:08:23:
Allen, your 310 should not start that hard cold. Are you using the primer position on the fuel shut off cable to start when it is cold? If you hold the cable out 1/4 of the way or so when starting engages the primer and puts more fuel in for starting. It makes a big difference. Wayne
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
