Re: Farmall 756 with German 310 ( few Questions)
Posted by Allan In NE on May 15, 2007 at 03:08:23 from (148.78.243.24):
In Reply to: Re: Farmall 756 with German 310 ( few Questions) posted by TGIN on May 15, 2007 at 02:24:10:
Yep,
My 310 shines the best when it is pullin' clear up against the nuts. Just absolutely impresses me to no end.
Put it on a hay rake or a planter and the thing acts like it is being insulted. Almost sticks out it's lower lip and "pouts". :>)
Has yet to use a drop of oil and runs for days on end on a tank of fuel. One of the best tractors I've ever owned.
Cold blooded as he!! tho; anything below about 50 degrees and I give 'er a quick shot of the good stuff. :>)
Allan
third party image
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
