Re: H in the shop
Posted by glennster on May 15, 2007 at 06:55:54 from (76.224.16.173):
In Reply to: H in the shop posted by Tom Windsor on May 14, 2007 at 21:34:20:
they arent too bad to change, you can do it from the outside. if the brake drum comes off easy, you are home free. slide her off, pop the seal out, put the new one in. the m i did had a stuck drum from rust, took a week of soaking with pb blaster and a brake drum puller to get it loose.
