Farmall Tractors Discussion Board
LEAKING LITTLE OIL
Posted by TRACTOR TIM on May 07, 1999 at 07:54:54:
I'm getting ready to paint, I've located a slight oil leak on the right side of the engine block. The leak appears to be from a seal for a tin type plate running below and parallel to the spark plugs (mid engine block area). There is a similar plate on the left side. What are these plates, what's behind them and is there any problem removing the plate and replacing the seal?....PS I found the engine #, thanks
Post a Followup
: Re: LEAKING LITTLE OIL
