Farmall Tractors Discussion Board
Re: LEAKING LITTLE OIL
Posted by The Red on May 07, 1999 at 08:04:45:
In Reply to: LEAKING LITTLE OIL posted by TRACTOR TIM on May 07, 1999 at 07:54:54:
Tim on the distributor side is the rocker arm inspection plate. That gasket gets to leaking pretty easy. When you take the plate off, you might want to clean out the chamber as best as you can.
Behind the manifold is the water chamber inspection plate. They don't usually leak unless you own a Dang Ol 1951 Farmall H with a SN of 366,221. Hmmmmmmm.
Post a Followup
: Re: Re: LEAKING LITTLE OIL
