Farmall 140 Need Hyd. Link Arm ?????
Posted by Keith Stromberg on May 16, 2007 at 14:25:07 from (74.244.168.169):
Finally getting a lot of the kinks out of the 140 that my fatherinlaw gave me. But today some how I bent what I call the draw bar or draw link. It runs down the left side of the tractor and connects to the rock shaft. Has a hook like on one end and a spring with nut on the other. The one on the tractor looks like it was made with the orignal ends welded to pump pipe. Were would I find one? Also the collar on the end of this same link bar ?? that connects to the rockshaf is way smaller than the hole on the bracket of the rock shaft. I saw were there is suppose to be a busching for it but its no longer avaiable thru IH. Can any one lead me in the right direction? I have looked all oner the web and ebay. But I am not sure what the correct name is also. And I do not find it in the manual I have.
Thanks to everyone for being so helpful to me hopefully one day I can return the favor.
Thanks,
Keith
