Re: No spark
Posted by the tractor vet on May 16, 2007 at 18:19:00 from (75.19.126.88):
In Reply to: No spark posted by CNKS on May 16, 2007 at 17:34:07:
Ah your problem is that the wire from the starter button should go to the selinoid and a wire from the R therminal should go to the Points side of the resistor and the wire from the KEY switch should go to the resistor . The only time that ya should shoot 12 volts to the coil is when ya crank the engine . No maybe i miss understood ya . Also chek to make sure that the dist. to block is clean and giving a good ground , Also it could be your points as more then once i have gotten new points that PLUM DON'T WORK and will make ya get into the purpel bag.
