Re: Priming live hydraulic system on 400
Posted by Wardner on May 16, 2007 at 20:14:20 from (4.154.243.244):
In Reply to: Priming live hydraulic system on 400 posted by Big Country on May 16, 2007 at 19:02:59:
The advice normally given on this board is to pressurize the reservoir. I don't know if that works because I would think both the inlet and outlet of the pump would be affected and there would no pressure differential.
I do it differently and I believe it is the way the manufacturer intended.
At the top of the pump, you will see a little bleeder ball that is held in place with a concealed spring. Both the Pesco and Thompson pumps have it. Hold that down for a few minutes with the engine off. If that doesn't work, make something that will move the ball and place a heavy weight on it. Let it sit overnight or until oil leaks out.
