Re: M cast iron shift knob, old seat, etc.....
Posted by chadd on May 17, 2007 at 09:35:12 from (155.92.32.46):
In Reply to: Re: M cast iron shift knob, old seat, etc..... posted by NDS on May 17, 2007 at 07:37:24:
You have one of those too? Some people have seen our 1940 M and they always say that we have such a nice later M. That is when I show them the serial number. "That CAN'T be a 1940?" Yep, all late 1939 and 1940 casting codes, but the swinging drawbar with a roller, The 800 psi belly pump, the pressurized radiator (came with non pressurized radiator), distributor ignition (came with magneto), rubber tires (came with steel), late M style pto assembly, Super M or MTA belt pulley (1954 casting date), later style spring-shock absorber seat, and the two way hydraulic attachment. The only thing that gives it away is that it still has the old style front bolster, the dual tank system installed, and the old style gas tank mount.
