48 Farmall Cub Rod Bearings
Posted by Mark JF on May 18, 2007 at 10:50:08 from (67.109.213.210):
How hard to replace rod bearings in a Cub? Here is my problem. When the motor runs at normal or high RPM's it sounds fine. But when I lower the throttle so the motor is bearly idleing I can hear a knock in the motor on the carb side. Oil pressure is real good the needle stands right in the middle on low idle. Does this sound like a rod knock? What else could it be?
Thanks in advance.
Mark
