Re: Spark found
Posted by CNKS on May 18, 2007 at 19:08:23 from (204.249.178.32):
In Reply to: Re: Spark found posted by El Toro on May 18, 2007 at 06:45:08:
I might have to do that -- I am 99.9% sure it is, as with a good light I can see the piston. I'm currently comparing TDC with up to 4 degree advanced static timing. IH manual says TDC, IT manual says 2 degrees before. I am not sure that the ballast resistor is not somehow messing me up. I'm going to remove it and hope I don't fry something. The spark looks good to me, but something is still not right. Carb is clean, good fuel flow.
