Re: Help Identify This Planter Equipment
Posted by HAS on May 19, 2007 at 10:07:32 from (68.12.1.188):
In Reply to: Help Identify This Planter Equipment posted by keith stromberg on May 19, 2007 at 08:44:08:
That looks like a planter that mounts on an A, Super A or B. It would bolt to the right side of the tractor over the mounting bolts for the lift arms for cultivators and also to two housing bolts forward of that.
The planter is sprocket operated off of the right rear wheel housing, inside. The 4-bolt plate comes off and you bolt the sprocket drive on there instead.
The planter should have the sprocket drive, an idler sprocket, drive shaft and clutch assembly, hopper and plates, feed tube, furrow opening discs cover discs and packer wheel.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
