Re: Sleeve installation farmall H
Posted by Gauger on May 20, 2007 at 09:26:44 from (4.252.155.214):
In Reply to: Sleeve installation farmall H posted by Aaron B on May 20, 2007 at 06:52:13:
Didn't the new sleeves come with instructions? I've done a few and the instructions say to use diesel fuel or light oil. You can put the flange in the counterbore upside down to check the standoff dimension. The sleeve should go in 1/3 to 1/2 way by hand and then a light tap should do it. The fit should be very light press. The freeze/heat method should not be necessary if all dimensions are OK.
