Re: Purchase Cub? Need info
Posted by Haas on May 20, 2007 at 13:23:51 from (12.65.72.152):
In Reply to: Purchase Cub? Need info posted by Jerrycpp(WA) on May 20, 2007 at 12:55:36:
Check the final drives, the front bolster (bottom part of the radiator) and the engine block for cracks. Since you say the engine is rebuilt, it should be OK. A new 60 inch Woods mower for the Cub will run you $2000 or so. You can probably find a used one for less than $1000. IH also made a 42 inch mower for the Cub which is more appropriate for it's power. With the 5 ft, you can only mow grass that is not very high and much of the time you will be in 1st gear if the grass is even moderately high.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
