Farmall Tractors Discussion Board
Re: Help-Fast Hitch Tillage
Posted by TomH on May 07, 1999 at 21:57:44:
In Reply to: Help-Fast Hitch Tillage posted by Steve (MD) on May 07, 1999 at 03:36:52:
Regarding the disk, like all tillage tools it should float also. Try to put down pressure on it and you'll lift the rear wheels and lose all traction (fast hitch can easily lift the rear of the tractor off the ground, in fact you use the drawbar to lift the rear if you ever want to adjust the tread width). There should be a bar that connects the touch control arm to the pivot point that adjusts its height, which controls the pitch.
Post a Followup
: Re: Re: Help-Fast Hitch Tillage
