Farmall Tractors Discussion Board
Help-Fast Hitch Tillage
Posted by Steve (MD) on May 07, 1999 at 03:36:52:
I started using the plow and disc that came with my 200 to work up about 4 acres that seems were not tilled for several years. I read the operators manual and it had a warning against using the lift to control plow depth-it said your supposed to use the pitch control instead. No matter how I adjusted the pitch control, the plow wanted to make its way to China. Any suggestions? Also, how are you supposed to rig a disc with a 200? Should you use the hydraulics to provide down pressure, or heap some concrete blocks on it? Should I use the pitch control with a disc, or is it supposed to ride flat whenever the pitch control is locked (put on the pin on the tractor frame.
Thanks...Steve
Post a Followup
: Re: Help-Fast Hitch Tillage
