Re: Can HYD system oil can get back in to the eng
Posted by CNKS on May 20, 2007 at 19:06:20 from (204.249.178.32):
In Reply to: Can HYD system oil can get back in to the engine posted by Larry in GA on May 20, 2007 at 13:58:15:
The o-ring is generic, cost maybe a quarter, speedi sleeve about $25 at any bearing supply place, maybe even NAPA if you can explain it to them. But, the hole that the shaft goes through has to be enlarged to accept the sleeve, best to have a machine shop do it, you are still at less than $100. If the shaft is not worn too much, the o-ring alone may do it, but I can't promise that.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
