Can HYD system oil can get back in to the engine
Posted by Larry in GA on May 20, 2007 at 13:58:15 from (71.29.150.239):
1953 Super C
Is there anyway that HYD system oil can get back in to the engine oil? I seem to be loosing HYD system oil faster than I can find where it is coming from
I rebuilt the auxiliary control valve a little while a go and that helped (but I could see that leak). I'm leaking around the rear lift cylinder a little but not as fast as the oil disappears. and if it is internal to the pump how much of that cluster has to come apart to stop it.
It is 50 + miles one way to the Case IH dealer for parts and if it isn't newer than 1990 they are lost most of the time.
Thank you for your help
Larry
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
