Re: farmall m re-starting trubles
Posted by Owen Aaland on May 21, 2007 at 05:42:34 from (198.70.47.171):
In Reply to: farmall m re-starting trubles posted by james in mo on May 20, 2007 at 14:49:01:
A bad condensor can cause just the problem
you are descibing. (Jumping from 12 volts -
will start right up. Pull it two feet and it will fire
right off. Crank over good on 6 volts but will not
start.)
Check for weak spark while cranking.
