Re: Oil Pressure on 140 Farmall
Posted by Jim in NC on May 21, 2007 at 11:15:13 from (172.164.243.30):
In Reply to: Oil Pressure on 140 Farmall posted by migraine on May 21, 2007 at 07:30:22:
I have an early 60s model 140. When cold, the pressure gauge moves up about 2/3 of the way then drops to barely registering when hot. I checked a few times by removing the valve cover to see if upper engine parts were lubed. Everything seemed ok. I have used this tractor since 1978 with no engine issues and it is still going strong. I do have to add a quart once in a while. Hope this helps.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
