Re: Oil Pressure on 140 Farmall
Posted by Haas on May 21, 2007 at 15:10:23 from (12.65.36.171):
In Reply to: Oil Pressure on 140 Farmall posted by migraine on May 21, 2007 at 07:30:22:
If you have 15-20 psi oil pressure when it's hot, you will wear out before it does. I had a super A that was barely above the red at full throttle when it was hot. Used it at least weekly with a Woods mower for 9 years. I've never done this, but I hear one thing to check is the cover on the oil pump (You'd have to remove the oil pan) to make sure it is not warped and letting oil leak. Also, are you sure the gage is good???
