Farmall Tractors Discussion Board
Re: Farmall M backfire
Posted by Bob M on May 08, 1999 at 06:44:48:
In Reply to: Farmall M backfire posted by JustinB on May 07, 1999 at 21:36:29:
Could be as simple as late ignition timing, worn out or badly adjusted points, dirty plugs, valve lash set wrong, or carb set too lean - simple stuff to fix.
Worst case scenario: Bad valves.
Post a Followup
: Re: Re: Farmall M backfire
