Re: fuel line issues
Posted by El Toro on May 22, 2007 at 04:13:22 from (64.12.117.8):
In Reply to: fuel line issues posted by nspec on May 21, 2007 at 17:36:39:
You push the copper tubing into the compression fitting as far as it will go. You should be able to start the compression nut by hand after installing the ferrule on the tubing. You should be able to tighten the nut by hand for several turns before using a wrench. This will keep you from cross-threading. Probably a 3/4 turn with a wrench is enough. If it seeps gas, snug it a little more. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
