Re: M hydraulics?
Posted by RustyFarmall on May 22, 2007 at 05:29:19 from (66.43.253.62):
In Reply to: Re: M hydraulics? posted by M.Rad. on May 22, 2007 at 05:04:57:
Yes, that is correct. The one on the right, and the upper, or forward one on the left, are connected to the same spot on the pump, kind of like a "tee" fitting. The "delay" was intended to be used with a set of cultivators, where part of the cultivator was mounted on the front, and part of it on the rear. The rear part was connected to the delay, so it could stay in the ground a little longer when the cultivator was lifted at the end of the row. The idea was good, in reality there wasn't much difference.
