Re: M hydraulics?
Posted by Nat 2 on May 22, 2007 at 05:51:06 from (64.80.110.50):
In Reply to: Re: M hydraulics? posted by M.Rad. on May 22, 2007 at 05:04:57:
If you are thinking, "hook one hose from the cylinder to the front left, and hook the other to the right," then you are DEAD WRONG and you will break something!!!! Both these ports are ONE-WAY hydraulic ports. They both apply pressure at the same time, when you pull the lever. You can't use them with two-way hydraulic cylinders. If you hook them up, one to each end of a two-way cylinder, you will blow a hose, blow a fitting, blow the cylinder, or worse, blow the belly pump in your tractor!!! DO NOT DO IT! You need to add a two-way hydraulic valve to the tractor to operate a two-way cylinder. This is fairly easy: 1. Obtain an open-center, dual-acting spool valve from your local Tractor Supply. 2. Mount it in a convenient location on your tractor. 3. Run a hose from the right port to the IN on the valve. 4. Run a hose from the OUT on the valve to the fill pipe. Close the vent on the cap or replace it with a plain pipe cap, or you will have hydraulic fluid EVERYWHERE. 5. Run two short hoses from the work ports on the spool valve to the rear of the tractor. Terminate these in Pioneer quick connects so you can easily disconnect the grain drill from the tractor without spilling large quantites of oil. To operate, you pull the belly pump lever and lock it back. Use the spool valve lever to run the grain drill up and down.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
